The first work completed using an AI workflow
First, use banana-generated images for badge design in the early stages, then generate smart grids with TRIPO AI and divide the blocks between grids. Next, quickly form the edges using the blocks directly in ZBrush, followed by standard operations such as SP texture mapping and 8Monkey rendering. The integration of AI will significantly improve the efficiency of model production. Many companies have already begun adopting AI workflows. Although for 3D modeling, the formal pipeline workflow with AI integration is still under development, this is undoubtedly the future direction. Keep it up!
