The Fiber Material
Hello Fellow Zbrushers
I’m have a problem rendering a turntable using the Fiber Material. I’m using the BPR with AO turned on. I keep getting the fur flickering in the animation. Is there a setting I’m missing? Or I’m I out of luck.
Thanks to All
Is your Fiber button ON in the render panel?
Thanks andreseloy
Yes all the settings are on.
I’d like to bump this thread as I have the same question.
The fibers render, but if you animate the camera, every frame’s fibers are generated diferently.
to test this, open the fiber demo (the one with the egg). Show the timeline, set a keyframe, move the view (doesn’t matter where) scrub the timeline and set a new keyframe. Now do a BPR render, you should see the fibers, now ctrl-shift click below the timeline to record the movie, it should go through and render every frame, once done play the movie and you will see the fibers go crazy!
Anyway we can use fibers in an animation? Or are we stuck with a single frame?
