Hi i have problem i have lot of subtools but when i go texturing one of the subtool it is texturing the image on model but when i chose to other now its not texturing i dont kow why but when i click on the one wich i textured before texturing on that subtool is working can you help me?
Hello there,
By texturing, do you mean when applying a texture to a brush (Under the Texture Palette), or using a Texture Map on the entire subtool (in the Tool Palette under Tool: Texture Map)? The latter requires the subtool to have UVs. Each subtool should also handle the textures uniquely, which means you’d just have to select the second subtool and go through the same steps to reapply the texture in order for it to show on that subtool as well.
If the second subtool is not letting you do this, check to enable that it has UVs assigned (if Tool: UV Map: Delete UV and Tool:UV Map: Morph UV are greyed out, then the subtool doesn’t not have UVs).
