Texturing only a part of an object ?
Well it’s not an obvious, easy way to texture the part of an object … I tried many ways (masking, polygrouping etc) it didn’t work… maybe I was doing something wrong I tried subtools but it’s not a good solution for me … here is the part of the architectural wall I need to apply texture only to flat walls … arches should stay untouched… again splitting object is not the solution … sooo any ideas ? :):slight_smile:
Did you try Projection Master?
No I didn’t ) u think it will solve the problem
? I don’t know how to use projection master ))
http://docs.pixologic.com/?s=Projection+Master
@MasterBrush
This should not be posted in the Main Forum. If you have any questions or want to know how to do something, then please post them in the Other Questions & Troubleshooting Forum. This thread might get moved by a moderator.
ok)
proj master is very good but i did it by another method … i just hide polygroup which i didn’t want to participate in displacing . that’s all
thank u for ur advice…
