Hi. Why are my Textures being applied from the Texture Palette and not from the Texture menu on the left? See attached.
Best Regards
Stephen
Best Regards
Stephen
ZBrush 4 allows you to apply textures to each SubTool individually. This is a huge step forward from 3.1 and before which could only use one texture for the whole model.
In Z4, to apply a texture to a model you need to choose the desired SubTool and then use the thumbnail in the Tool>Texture Map menu. Just like you show in your picture.
Thanks, so what is the Texture area on the left used for?
