Texture resize when i complete texturing
Hi all!..someone know why my texture when i projection master–>drop now resize to 1024x1024. source texture size is 4096x4096.
Projection Master will paint on the currently-selected texture. If no texture is applied when you drop the model, PM will create one for you. But it will be at the default size of 1024.
The solution is simple: Before you use Projection Master, assign a blank texture to the model that’s the size you want. (Set the dimensions in the Texture palette, then press Texture>New.)
thx! it working
