I was playing with Zbrush today actually, it’s really good, got some questions if anyone can help. (I’m also sending a mailshot so ignore it if you read it here)
I’ve been messing around with the idea of making a statue for a project in ZBrush. I can’t seem to find the answer on the online ESC tutorials.
I was thinking of modeling a medium poly model, UV mapping, texturing in Maya and Photoshop, importing into ZBrush then adding the detail. After that I will export medium poly model back to Maya and use displacement methods for the final render. As the texture was done in medium poly and as long as I don’t displace too much which the texture work and not look stretched ?
The alternative I thought was not UV mapping the model but taking the medium poly into Zbrush, adding detail, then making a UV map in zBrush, painting in photoshop…exporting the medium poly into Maya with displacement and texture maps. In theory this method means i should have a high resolution texture UV map that should fit perfectly in Maya.
The problem i see is that you have to render the mesh with displacement map just to see the texture because it might not look great on a medium poly mesh.
Any ideas which would be the best method ?
