Texture map export format
By default, zBrush export subtools texture map in BMP format when OBJ is selected. Is there a way to change this default format to JPG? how?
What you need to do is to clone the texture map to the Texture palette and export it as a JPG from there, or use the FBX plugin export (which has JPG as a diffuse map option). You can’t change the format exported with an OBJ.
