Texture does not show
Hello
When I choose a texture for my ImagePlaneX, it does not show up on the ImagePlane…
Somebody that can help me?
:confused:
any texture? or the one you created? are you using the imageplaneX .psd that comes with the tool? or did you just create one and apply that?
Adding pictures to show the problem always helps.
Thanks for the answer
As you can see…the imageplanex.psd do not show up… or any other texture…
What can I do?
:frowning:
Jiipiii …I found out…
ZBrush 3.1.2 does texturing in a NEW way … new palette
From the guide:
Before applying a texture, check if your ZTool has UVs, by clicking on Tool >> Texture Map >> New from UV Check button.
In the Texture palette, click Import and choose the texture to load from disk.
In Tool >> Texture Map menu, click on the empty texture map thumbnail to display the texture popup window. It will display all the default textures, and at the top of this window, in the User Textures field the previously loaded texture. Choose the desired
texture.
Now you should have your texture displayed on your model or SubTool.
:smiley:
