Symmetry Problem
I am having a wierd problem with symmetry, the brushes are working along x symmetry but the intensities are diff on both sides, I never had this problem before, Wats going on?
did you accidentally moved your model with transpose? sometimes when you do that it will screw up the pivot point of the model. Try to go to transform and click c.pivot and see if it revolves.
