i have a symmetry problem. when i start sculpting with x symmetry on, the z-Intensity is higher on the left side of the model. so the points get pushed out much higher.
Anybody know this porblem ?
sorry for my bad english
This indicates that the model isn’t truly symmetrical, or isn’t centered correctly.
Try pressing the S.Pivot button found on the right shelf. Does this fix the problem? If so, then the model was off center to begin with.
If you continue to have trouble, could you post some images?
this didnt fixed the problem, but i found out how to fix this.
i went to the lowest subdiv level of my model, did resym.
Smart Resym didnt fixed it.
maybe somebody has the same problem.
but thanks for the quick help.
