Symmetry misaligned and rotating subtool
Hello, I am having problems with symmetry becoming misaligned or displaces on sub tools once i use the rotation tool on them. For instance I appended a figure into a project and rotated him 45 degrees and I am no longer able to use it symmetrical sculpting functions because the original axis the symmetry seemed to be aligned to didn’t rotate with it. I tried using set pivot but I am having no luck getting back to my original symmetry.
symmetry isn’t stored for local rotations, only translations. You need to have your mesh sitting symmetrically on one of the axis to use this feature. Your best bet is to eye ball it back in to place and then mirror and weld the object to make it perfectly symmetrical again.
