symmetry issue
Hello
I have an issue with symmetry in a tool
if do the same changes in another tool, it works perfectly.
I don´t know what I´ve done in this tool to behave in that way.
thanks you
If you’ve moved it, you’ll have to make sure local symmetry is enabled.
I have local symmetry enable (I try to turn it off, but I got same problem)
I try to Unify my tool too, but I got same issue.
i found a solution, open another tool, and insert my old tool into… now symmetry works perfectly!
I still guess what I did to symmetry behave wrong.
If you save the ztool with mirror off, it will still be off when you load the ztool again.
ohh… Thanks you a lot!
:+1:small_orange_diamond:)
