Symmetry issue on imported ZTool
For some reason my symmetry is off when I enter edit mode.
Workflow is: Open Zbrush>Import Ztool>enter Edit mode = Symmetry off.
The mesh is from 3ds Max 2011 and in that program the mesh and symmetry is perfectly aligned to the grid.
Under the displacement settings in Zbrush’s tool palette i tried offsetting it, which could fix the problem but wont because it snaps over the point that would be perfect symmetry (not a suttle snap either where i could just ignore it).
Is their any other solution to fixing the symmetry? Or a way to slide the offset to the decimal without it snapping?
Suggestions/solutions much appreciated!
transform>L sym (local symmetry).
Max has a slight off set during export (as you see). You can either append your obj into a file that has sym already (a start up box will work). Or you can use goZ which will fix the problem as well.
Ah thank you! Sorry for the super big picture LOL!
