when i try to use the symmetry button (X), whils in projection master it doesnt work on both sides! can any1 help me and let me know how to do it?
thaankyou!!!
thaankyou!!!
Projection Master doesn’t use symmetry. It does have a double sided feature, which is used from the side. So anything that you paint on the side facing you will also be applied to the side facing away from you. This requires that the model be viewed exactly from the side.
If you’re not painting mesh deformations, you can use ZAppLink instead of Projection Master. This will let you use Photoshop’s tools to mirror what you paint. Then when you return to ZBrush it shows up as mirrored work on the model itself.
Great Help M8 Once Again!!!:d
