Hi! When everything is default then I can switch between shaders and RGB-colors are updated directly on my tool, but when I have used “Fill Object” using one of the shaders (ex. MatCap White Cavity) then I can’t switch between different shaders anymore? I then have to use “Fill object” for all shaders to see the change on my tool.
How do I make it work like the default tool again, so that I can switch between colors and materials without having to use “Fill Object”?
// Tennet
