surface pro3 UI scaling
Hello,
I just installed zbrush4r6 onto my surface pro 3 running windows 8.1 64 bit.
I am noticing that even though the screen resolution of the display is 2160 x 1440 my UI is really big and I don’t have the same screen real-estate that I do on my desktop 1600x1200 screen.
I was curious if anyone had any insights into what I could to do resolve this issue.
Below are attached screen shots from both computers.
ah nm, just found the solution.
Under display properties in windows you can “change the size of all items” it defaults to 75%, if you set it to 50% it will be closer to what you would expect in zbrush.
