Hi everyone!
I`m looking for some feedback and hopefully a solution to an issue I am having when running ZBrush 4R7 on the Surface Pro 3.
Initially everything works fine. You can create a Dynamesh sphere and sculpt happily, even load one of the custom models like the DemoHead and play around with that with the pens pressure sensitivity working fine.
The problem I am having is when I import an OBJ or load in a ZBrush scene I started on my desktop the pressure sensitivity drops.
You can see the problem in this video at around the 10 minute mark, when I import my Red Sonja model -
If possible could you try the following and reply with your results, to see if you get the same issues?
- Load ZBrush 4R7 64bit or 32bit.
- Select a Dynamesh sphere and test sculpt on it.
- Next load and sculpt on one of the tools which comes with ZBrush like DemoHead.
- This time import an obj file and sculpt on that.
- This is where things break and the pressure is lost.
- If you now try and go back to the DemoHead the pressure is still lost.
If you like you can even download the Red Sonja model from here - Red Model - So your using the same model.
Any feedback would be really useful and greatly appreciated!
The more people who try it the better and if it turns out to be a wider issue I will try and get Pixologic, Microsoft or N-Trig to come up with a solution.
Thanks everyone!
