Thanks for the advice scote, will take another look
changed a few things
deffo think my work is getting ‘cleaner’?
still playing. time to try something new I think!
First sojourn into Anime/Manga, thought I’d give supergirl a break!
Crits welcome
few things changed, would love a miniature of this
Hi all, quick question please? How would I go about adding a file to download. I have a base mesh Id like to give away
Thanks in advance
You could always host it on dropbox but if not, zip it up and go to the Attachments section of the Reply. Hit Upload Image or File. Then add your file.
Thanks Teyon
Few base meshes, mainly if any newbies want to play around, would like to see if they are of any use. Topology is terrible
https://www.dropbox.com/sh/2bouzqx9yoba88c/AACiszNG1GY-gqBJkafF00Laa?dl=0
Hi Roan
If you could save it as an Obj. file and post it I could 3D print it for you, it depends on where you live (country)
I am UK.
Jeremy
wow, thanks Jeremy, Im in Uk. What do you charge?
Depends on what size you want it and also whether any work is needed to get it to print, (looks ok to me but if you could post the obj. file I can then work with it to see what results we get.
I don’t do this as a business so my rates would be good
I am in the Midlands
Jeremy
Ok, will send an obj. Gonna do a little more work first tho. Thanks again
are we talking about the supergirl? Im really interested in 3D printing, thats the way I see the future going for a lot of things.
is the cape being thin, if it is too thin printing it might be an issue.
if it can be thickened up a bit (edges should be ok) then that would be the only issue I can see at the mo.
Ok thanks, Im going to try and use 3d Exporter from Zbrush. How much would you charge for a 10 inch print? What machine are you using out of curiosity, I can give you my email if you prefer?
Here you go Jeremycon, let me know what problems you come up against
https://www.dropbox.com/s/sx7wqc4vpzgbxev/Merged_PLATFORM2Deci.OBJ?dl=0
I use an Up plus 2 which goes down to 100 microns so the finish is quite good
i will look at the files and upload and let you know.
my email is [email protected]
cheers
Jeremy
Just a quick WIP, just need to pose
