Subtools Problem - Can't select main
Hi, I’m a total newbie into zbrush, and Im having some trouble with subtools, I don’t know if this is normal or is a bug that only Im experiencing since I was unable to find an answer anywere.
The problem is, I can’t select the main subtool, ex. If my mesh have 2 subtools and I select the first one, it automatically move down to the last subtool. The same issue happens on every model that came with Zbrush.
please help
hey hang in there zbrush has a very steep learning curve i still have problems with subtool options
but try this load the tool that u want then make sure it is in edit and draw mode and also selected in bottom subtool bar .
