I’m having a bit of an issue at the moment and was wondering if anyone could assist?
I’m working with Mac Pro/2.66GHz Quad-Core Intel Xeon/6GB (3x2GB).
I’ve built a model which will be appended to another model for finalization.
The problem I am having is when I “merge visible” all subtools to the first model and then rotate (under Deformation) after selecting the merged subtool some of the previous subtool elements do not rotate with the rest of the merged subtool.
Also when merging at 7.819 M polys I get the memory error, explaining that I have too many polys for my RAM to handle. I was wondering whether this was causing the issue above. I assume the only way out of this is to down each subtools polycount. when merging does ZBrush delete the hidden polys or does this need to be done manually.
I’m still having problems understanding the memory thing. I have set up Mem under Preferences, but it seems to be a little hap hazard.
Any help on this would be appreciated as I’ve put the project on hold until I know what the future holds.
Thanks
Mark
