Subtools, layers and what not
Quite annoyed, mostly because I don’t understand this sort of work flow.
If I import anything into Photoshop it’s imported into a new layer.
In ZBrush it’s replacing what’s in the scene rather than loading it into a new layer or subtool layer, I don’t want that, I want it loaded in as a new layer or sub tool layer…
So how do I make this happen??
Also, how do I have a permanent copy of Genesis from DAZ3D as subtool that I can grab any time I want to load fresh into a new work scene or as a layer for reference for it’s default shape??
One other thing. Is there a preference to change the folders it looks in first? I’ve created a work folder called RAMWorks Projects but when I restart ZB it goes back pointed to it’s default projects folder, this is time wasting for me to redirect it every time to my folder.
Thanks for the help!
For importing meshes as subtools, I like to use Subtool Master’s Multi Append tool. For importing images on a different document layer, I think you might have to create a new layer and switch to it first.
For lightbox I don’t know about changing it’s startup location, but you could simply place a Shortcut to your own folder into the /zproject directory. Then you’d only be a double click away from it every time you start up, which should be fast enough that it wont be a time waster.
OK… couple more questions…
If I really need to zoom in tight the view port up and disappears … I really need to know if there is an orthographic view option I can turn on. I get so frustrated when I really need to zoom in tight and can not.
Also, this is going to be a real strange one… if I have a symmetrical model and I’ve done a morph on one side of it and exported that for use in another program is there a way to mirror that to the other side and better yet is there a way to have it so that the unmorphed side adopts the morph and the morphed side is restored to it’s former??
If not it would be a wonderful feature to request for the next version or update. Would make life a little less stressful! lol
Thanks!
