subtools / group split
Hello
For some reason when I bring in an obj and group split into subtools my new tools original position has been changed. How do I prevent group split from causing this transform problem.
Thanks in advance
can you post an image of it?
I will not be able to post an image (sorry) but what is happening is I export an obj from maya and import into zbrush. I then aply uv groups under polygroups and then within the subtool menu I group split. I then have multiple objects and if I export one of them and import that obj back into maya the position has changed a bit. As a test I imported the original obj into zbrush then exported and loaded the obj backt into maya the the position did not change so it is isolated to something within subtools group split? What I do not know. Any help would be great
I know what you’re talking about now.
http://www.zbrushcentral.com/zbc/showthread.php?t=66066&page=2
look for aurick’s post…orange text
how are you exporting out your OBJ’s?
if you’re not using Subtool Master…do.
That…should…fix the problem.
