Hi there,
I had a problem using SubtoolMaster when I tried to mirror a model, it popped up an error note says, Zscript Notes, Interface item could not be found.
Any 1 had same problem before?
I am using Zbrush 3.5 r2 on windows.
Hi there,
SubTool Master is not compatible with R2. None of the plugins from 3.1 are.
You need to use R3, which includes SubTool Master and all the other Pixologic plugins that were scheduled to be updated for version 3.5. There is no further support for R2.
If you did not receive the upgrade info for getting R3, please submit a ticket in the Upgrade category at http://support.pixologic.com and include your 3.5 serial number.
