subtool question
I’m trying to append a model to another model but I can’t see it. It seems to be appended as it shows up in the subtools palette.
I tried saving it as a tool and then loading it before appending but the same thing happens. I also thoguht it might be a scale issue, so (in maya) I made sure the second model was frozen and set to world zero and and was the proper size relative to the first model. Still no luck.
I also get no visual preview of the model in the subtool palette. However, if I choose the second model in the tool palette it displays correctly. I can subdivide it, etc.
Any ideas for why the second model won’t show up when appended?
can someone please help with this?
This is a real pain as the only workaround would be to create the objects in ZB and the objects I need to add in are much faster to create and accurately position in maya than in ZB.
