Is there a way to morph one subtool into another subtool?
For example:
http://graphics.zcu.cz/Projects/Mesh-morphing
For example:
layers
Are you referring to turning layers on, then modifying an existing subtool, then dialing back and forth between its original form and its modified one? If so, I meant morphing between two completely different subtools, with likely differing poly counts. Is that possible?
I am.
I don’t believe you can do that inside of Zbrush.
