Subtool Master problem to install in Version 3.2 mac
Hi everyone, i’m trying to install Subtool Master for the mac, i have unzipped it and put it in the Ztartup/Zplugs but nothing is happened(Zplugin), what gone wrong???
with friendley greetings silberdenar
When you unzip a plugin, you will typically get a folder that is named after the plugin. Within that folder are the .zsc file that is the actual plugin, as well as a data folder containing everything that the plugin needs.
The most common mistake when installing plugins is to place the unzipped folder into your ZPlugs directory. This buries the plugin deeper in the structure, where ZBrush can’t find it. Instead, you want to unzip a plugin, open that folder, and then copy the contents of the folder into your ZPlugs directory.
In other words, the .zsc file and the data folder must be in the ZPlugs folder directly. If they’re buried any deeper, ZBrush won’t find them.
If this doesn’t solve your problem please post a screen shot of your ZStartup/ZPlugs folder.
Thanks,
thanks marcus i’ll try that:-)
with friendely greetings Silberdenar
