Subtool Master mirroring problem
Hey all. Been using Zbrush professionally for a while now and was wondering if anyone else has come across this problem and if there has been a reason/solution discovered.
Whenever I use the plug-in Subtool Master to duplicate or mirror a subtool, the new duplicated/mirrored subtool becomes scaled up greatly. Any thoughts would be great.
Also, I am working in 3.1 on PC. I saw there was some problems with 3.2 on mac so just to be clear thats not the case here. Thanks!
heyyyy try undo(cntrl+Z) dat time for the scaled subtool. Because i was also having the same problem. i know dis is not the exact way. but it can work. :slight_smile:
It’s possible that what you’re experiencing is related to this: http://www.zbrushcentral.com/zbc/showpost.php?p=546514&postcount=23
