Hi, I set up an image plane which intersects my model, and when I try to sculpt the section of the model(a seperate sub tool) that is behind the image plane it wont move the verts. I can only sculpt the parts of the model that are in front of the image plane. Is my Zbrush bugging out? it seems to be acting strange
In ZBrush 3.5R3 that is unfortunately how it acts rights now when you have transparency enabled but do not have Preferences > Draw > Ghost Transparency enabled.
The best solution I can think of is to assign a hotkey to the Ghost Transparency switch and toggle that when needed. If Ghost Transparency mode could also show the texture it would be a different matter but I am not aware of any way to do that.
hmmmm thanks I’ve been hiding/re-showing the image planes…
