Hi.
Is there a way to group subtools in the subtool box? Now, with Fibermesh, one model can have a lot of subtools. Is there a way to group these and reduce how much scrolling must be done to find things?
Thanks!
~S.~
Hi.
Thanks!
~S.~
Nope.
However instead of scrolling you can hit ‘n’ and a window pops up under your mouse with all available subtools in a grid, similar to hitting ‘m’ while a mulimesh brush is selected to switch between the meshes.
Just be sure to name your subtools as you go along as it can get confusing if you’ve got a lot of fibermesh tools (they end up looking so similar in the icon it’s hard to tell which is which).
Alternately you can alt+click on any subtool in the document and it will select it. This can be tricky though when the tool you want to select only has a bit of area peeking out from your active tool, because the brush cursor will snap to the active tool when it gets close
-J
Thanks, J.
Too bad about the grouping. Photoshop has nice grouping functions.
~S.~
you can use the timeline as a way to group subtools.
