Hello
I have problem with hires mesh. Dots appeared suddenly by himself.
You can see, this dots matchs with lowest division vertexes.
And overall Polyframe view is strange on skull and jaw. teeth has normal polyframe
Whats wrong?
Hello
Whats wrong?
It’s the material that you’re using as close as I can tell without seeing more of your interface/settings.
The Bumpviewer materal turns the color black into a bumpmap displacement. It doesn’t matter if the black is coming from polypaint, a mask, or in this case the polyframe wire color.
