Subtool disappears after decimating
Hey everyone,
i tired searching for this problem to see if anyone else has had it but i didn’t really find anything.
I was wondering if someone can help me, I’m trying to decimate a subtool (2.3 million polys), (it’s made up of a few different objects. so it’s not air tight or anything). but when i try to decimate it, after it finishes the object just disappears. the thumbnail in the subtool drop down disappears too and i can find the object anywhere, I hit the F key to try and frame it but nothing.
has anyone seen this or maybe know how to fix it.
Thank you very much.
delete your cache within decimation master. Make sure all of your meshes have actual names.
Then try again.
Thank you for your help, I actually was able to solve the problem by dynameshing some of the problem pieces and then decimating that.
But I will try this solution first next time.
Separate your objects and decimate them separately and then merge them back into one subtool again.
Just found out that this also happens when there is a layer active in the layers tab. Make sure those are baked before decimating.
