Subtool center problem
Hi - I have come across a problem that I have never seen before in any of my previous models and I have no idea how to fix.
When importing objects and appending them as subtools I can’t get them to line up the same as they did in MAX no matter how I try.
All objects have the same centre point (0,0,0) and have the transformations and scaling reset.
I have illustrated the problem below
  1. You can see the three creatures in MAX on top of each other - they all have the same centre and should append as such in ZBRUSH.
  2. This picture shows the creatures appended to each other - they do not line up at all and dont match what I had in MAX at all.
  3. This is after I have applied a DEFORMATION - UNIFY onto each of the subtools. The two appended subtools snap to the centre of the first.
Can anybody help me with this problem - it’s driving me mad!
what are you export settings from max…and which version of max are you using?
also, what are you import settings in Zbrush…and which version of Zbrush are you using?
