substance painter with zbrush
hi guys, i will use a mesh made in zbrush, painting in substance and then render in keyshot…is possible?? Do you have a tutorial…if it is possible!
The way that Keyshot uses materials is a bit quirky. I don’t think it is really fully compatible with substance painter. For example substance indicates that a material is metallic with a texture when Keyshot uses a shader. Keyshot doesn’t use the PBR system of substance painter. This doesn’t mean it is not possible to export textures between both programs but it is far from a straight forward task. Also the current version of Keyshot is limited because it can not blend shaders or texture types, something that apparently it is going to be solved the next version.
Thx for your help…
I believe marmoset toolbag will work ! Any other 3d package will work with importing, also unreal game engine is free , and may also work with that pipeline! DJ
