Hey all, I used zsketch to create some base geo, made a skin from that. Now when I try to subdivide the model it does subdivide the model but it won’t create a subdivision level for me.
Anyone? Any ideas whats going on here?
thanks!
thanks!
I’ve figured out running dynamesh on my model will allow me to subdivide the model afterwards and have subdivision level history. If someone can explain why this is I’d greatly appreciate it as I’m still confused.
Hey bloodstorm
I had a look at you problem seems to be working fine for me! Just to double check,
Zsphere> Draw geo > Density Slider to adjust density of skin > Make Adaptive Skin > In Subtool > Append > Skin_Zsphere. From there the Density from earlier will set the number of SDiv under Geometry.
Hope this helps!
Update…
I’ve just noticed that if a mesh has a slight amount of masking on it! If you try and SDiv it, it shows that you have division on ActivePoints but not on SDiv slider…
I learn"t something new
Cheers
