Hello,
For 5 hours i’ve been stuck with a very annoying subdivision issue. When subdivising, some vertices of the mesh moves Very far. I tried multiple .obj export settings from max, nothing changes. I also tried to smooth it in max, then export it: same messy result.
I believe that the mesh topology might have a role in this issue, but on other subtools i have similar topology without any problem.
Here are some images, you will understand my problem a bit better i think.
In a few days you will see the result in my sketchbook, check out. ^^
