Subdivision Edgeloop Hybrid Modeling
I’ve just fineshed a quick head modeling study within ZBrush & it was blindingly fast! ok so there’s no ears, its just an experiment! I created my head template within truespace then exported it as .obj
  • i created a basic head mesh of 422 faces (No. of faces not Important) using edgeloops to lay down important detail areas
  • you may notice nonstandard faces, this is sorted by a quick subdivide (i used only one instance of subdivision)
  • after importing the template into ZBrush i gave shape to the head in the usual way
when i give it some ears (i hate ears!) i’ll make the template available people want it or find it usfull.
This is my first WIP on the forum & my first New Topic!
Hy Equalizer Congratulations and welcome.
Your work is very nice to me. I think you have reached a very detailed head, dont worry by ears…I can see your artistic talent¡¡¡ and always I have to thank those like you that allow to learn sharing your own way of make beutiful post…
Confratulations
Really nice Equalizer! Texturing is great too! :+1: :+1: :+1:
Hey Equalizer! Nice head modelling. I posted a few heads the other day. If you are interested! :slight_smile: http://www.pixolator.com/zbc-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=011640
hi equalizer, nice head. there is also a method to get edgeloops with zbrush. developped by grub. and your ears are attached in one modeling session. i use that every time i model a head. very fast…
Thanks for the input peeps
kokoro
I checked out grubs tutorial it’s excellent, I gave up on my own zsphere experiment too early it seems I didn’t keep my zshphere model so simple doh!
I checked out those all your gallerys
The standard is incredibly high!
Mahlikus I cant wait to see more of The Mahtopia Project.
:cool:
Now for some more heady goodness! this time in ZSphere Form & %100 ZBrush. This time i was successful.
This shows the progress of the model
And here is the finished head
this shows how nicley the edgeloops turned out
I hope to post a ZScript of the modeling session soon.
:slight_smile: hello Equalizer… there is something i really don’t understand in this question of low poly! as the joined pict, if i begin modelling in low poly, ok, that works, but as soon as in want to have a smooth finish,(from 1 to 2) i must divide and come back to heavy models! how do you go to nice smooth models, staying in low poly? … thanks for explanation! friendly M[
Marced , I hope I can help out here
In the Modifiers Tab of your tool next to Smooth (which is set to 0 standard , hopefully 1 by you) there is another thingie Divide too which is set to 3 standard I think , Set it to 6 or 8 and it should be smoothed without you dividing it manually with the divide and smooth buttons.
:slight_smile: ah thank you the namek! i never consider theses options! it seems to have always something more to try in zbrush! amitiés M.
Hey equalizer. That’s a really cool way to set up edgeloops. Fantastic tip.
Grassy Noel www.3dluvr.com/glenn
hewy equalizer, you got it ! very well done. glad i could help. :wink:
Hi Equalizer
Great post !
And show that the Namek knows all the options :wink: (n’est-ce pas Marcel :slight_smile: )
Pilou
Yeah thanks Kokoro great tip also thanks to Grub.
Matvara great variaty try modeling some female heads also.
:+1:
