Hey all,
How do I export a single subtool???
Thanks a lot.
_K
Hey all,
Thanks a lot.
_K
select that subtool.
tool>export - near the top
everytime i try that it saves all of the subtools as well, even if they arent showing.
It sounds as though you are using SubTool Master. There’s no need when you just want to export a single subtool. Simply select the subtool and then press the Export button that’s at the top of the Tool palette.
I wasnt using subtool master actually. Heres what I was doing. I selected the subtool I wanted to save, then turned visibility off for everything else. I clicked “save as” and renamed the file. When I opened it i noticed it was a huge file. I checked and saw that all of the other subtools were still there.
I tried to export the subtool, but my only option was to export it as an obj.
What am I doing wrong???
Thanks a lot.
_K
We misunderstood what you were wanting to do. ‘Export’ means saving out as an OBJ (or DXF) for use in another program. To save a single subtool for use in ZBrush this is what you do:
Marcus beat me to it…
ahhh, thanx. Yeah Im sorry about the mix-up. I just wanted to save a copy of a single subtool in a separate file. Thats what I needed thanx a lot folks! :)_K
