sub master tool error
hello
i have an further problem… sorry if i nerves :wink:
i have 3 subtools and like to merge it with subtoolmaster.
after execute i get an error:
skript: SuptoolMaster_4r6.txt
ERROR:Tool:SupTool:uv
IN:…
what i doing wrong?
thank you for help
samy
I think you’re trying to merge ZSpheres in preview mode. You will have to make them into polymeshes first by pressing the Tool>Make Polymesh3D button. This will create a new objects in the tool palette that you’ll need to append as subtools.
many thanks marcus… i will try this
…you right, my zspheres are still in preview mode…
but i “convert” it with the “make adaptive Skin command” before the error displays
Yes, OK, but you need to select the new Skinned versions. They are in your Tool palette with names beginning “Skin_”.
