This post was flagged by the community and is temporarily hidden.
The studs on the helmet are very long. -They should be just half the length.
Thanks Peter for your critiques.
but it’s M18 not M36.
Ok, sorry I thought M36 was without studs.
The original 1916 I have on the shelf has short studs, just wide enough to fit the stirnpanzer on.
Keep up the good Work.
and Merry Christmas!
Thanks Peter,
I referred to the pics I found on the web, some of the studs are short, others are not, so I referred to the longer ones to exaggerate the character of the helmet.
Even so, it maybe stick out a bit longer, I’ll recheck the pics and consider to fix it.
Thanks a lot for your straightforward critiques, I appreciate it.
Well the web can be a mess allright! But you are right, the pictures of 1918 helmets are all with the extended studs. So we both learned some histroy here
The top one is 1916 like the one I have, and there are some color suggestions here:
http://www.warrelics.eu/forum/steel-helmets-3-reich/m1916-wwi-german-helmet-what-color-8480/
eksample 1918:
http://quanonline.com/military/military_reference/german/imperial/headgear/mail.php
-Is she going to be a tank driver?
