stroke
Hello,
I would like to change the “spacing” in the “stroke palette” when I use for example the “clay” brush with “alpha 47” but it doesn’t work.
what can i do in this case.It is possible to change it?
thank you
bye
I HAVE zbrush 3.1.
nobody answer probably we need to buy it.
Try this: Stroke-> Click on Lazy Mouse. From here adjust the Lazy Step value for the spacing of the alpha. That should help you acheive the results you need.
yes,thank you.
What about “spacing” in the “stroke” palette.
bye
This is a new design I have done with zbrush 3.1 but I would like to improve it.
