Strange problem with timline animation
Strange timeline behavior when using a saved project file. When I set keyframes for the camera it functions as expected when using the scale parameter but when rotating the model it appears to rotate correctly when setting the keyframes but upon playback the model does not rotate around its axis but it seems the camera is rotating around its own axis causing the model to rotate off screen. When I save the subtool and then restart ZBrush and load it into a new document the timeline rotation works as expected. Is there a way to reset the rotation? This problem seems to be saved with the project file.
Any thoughts?
I had the exact same problem. I tried every setting in the Movie Palette. I reset Position, Grid, Perspective, exported out OBJs and re-imported, all to no avail.
Here is what fixed it for me:
I went to the Tool:Preview Dropdown and stored a new orientation for every subtool in the stack. And that was all it took. Interpolation went on as normal.
This is not the first time this has happened to me. Unfortunately, I am not a very experienced user, so by the time this error occurs, I have made so many steps, I can no longer tell which one borked it up. My best guess is, it happens, when you flip symmetry axes because I had my tool rotated sideways for a while and made adjustments. Let me know, if this works for you.
