Straight lines in sculpting?
Hello.
Is there a way to sculpt (or polypaint) straight lines? (without using projection master)
Thanks in advance
shift will snap to 45 degree increments by default.
I thought shift will activate smooth? :qu: :confused:
The Smooth Brush will become active with Shift pressed only before you start a brush stroke.
If you LMB-click first, then press shift and then drag, ZBrush will snap-lock your stroke to the closest 45 degree angle and let you draw out a straight line.
