Hello,
Is there any way to stop the model from rotating every time you (accidentally or not) click outside of your model. For example, when sculpting the indents in the fingers, I like to start from outside the model, but this makes the model spin around and you need to set your model in the right angle (again) and start all over. Seems to happen a lot.
Is there any way to overcome this problem?
Hopefully someone can help me because I’ve search a lot on this question. It isn’s a mayor problem but it’s just annoying
. So if anyone is having the same issue, let me know. Maybe I’m doing something wrong and could it be a simple fix?
TNX
