I’ve put the UIStarter_Z4R2_V1.zsc.zip in my zplugs folder as suggested in this thread, but I still lose UI elements.
Ironically I lose Active Points Count which is there in the default UI, and which I’d very much like back.
Any wisdom on this?
Any wisdom on this?
If you have updated to ZBrush 4R4 Patch 2 then you do not need to use that plugin and doing so will likely cause problems. If you have not updated to ZBrush 4R4 Patch 2 then you should do so (see the sticky at the top of this forum).
