startup crash
Hi, I upgraded from 3.5R2 to R3. It was working but now when I try to start it I get a fatal error with the following details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: ZBrush.exe
Application Version: 3.5.3.0
Application Timestamp: 4b0bfb06
Fault Module Name: ZFileUtils.dll
Fault Module Version: 1.9.1.0
Fault Module Timestamp: 4798dc87
Exception Code: c0000005
Exception Offset: 000031b8
OS Version: 6.0.6002.2.2.0.256.6
Locale ID: 2057
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
I’ve tried a full uninstall, reboot and reinstall but still get the same error.
…please help!
Thanks
Have you tried running a virus scan on your computer?
The fact that uninstalling and reinstalling did not fix ZBrush indicates that the issue is computer-related rather than ZBrush-related.
Also, what has changed about your computer between now and when ZBrush last worked? Have you changed hardware? Installed any new software or drivers? Had to do a system restore or something like that?
Nothing has changed about the machine as far as I know. Versions 3.1 and 3.5R2 are also installed on the machine and working correctly so perhaps you could tell me what 3.5R3 does differently, are there other prerequisites, is there a way we can debug this problem.
One thing I noticed but cant see how this would make a difference but 3.5R2 is installed to a non standard folder (“program files(x86)\zBrushR 3.5R2”) where as 3.1 and 3.5R3 are installed to the default Pixilogic folder.
I am running out of idea’s so any help is appreciated.
When you did your full reinstall, did you delete the 3.5 R3 folder after uninstalling? If not, could you try that?
