Start ZBrush in texture mode?
Hey there!
Quick question, is it at all possible to initialize ZBrush in a sort of, texture mode?
Why I ask. I just got through 30 minutes of texture painting, only to realize that my smooth brush still had zadd enabled -_-
lol. Alternately, is there anyway to turn off zadd/zsub for all brushes? (like a switch or something)
Thank you kindly.
A couple options. There’s a custom toolbar as well as some custom UI’s on the forums and the possibility of you recording a script or macro which initializes your settings.
Thanks Doug!
While I don’t think I will go about recording any macro’s since I want zadd/sub disabled on ALL brushes, I will definitely check out the forums for those custom scripts / ui’s.
Any chance you have a link to those? No worries if not. :slight_smile:
http://www.zbrushcentral.com/showthread.php?172786-QToolBar-1-0-Released
Hey Doug!
Thanks for the link man, unfortunately though it is of no use to me, though it looks like a wonderful script which I may end up trying anyways.
I appreciate the effort. :slight_smile:
Cheers!
Presumably you only use a few brushes for polypainting? The simplest thing would be to save new versions of those brushes with ZAdd switched off. Save them to your ZStartup/Brush Presets folder and they will be available every time you start ZBrush. Perhaps give them names starting with Paint_ so you can easily identify them. You could then make them part of a custom interface arrangement, even a special UI that you used whenever you were painting, if you wanted.
Great idea! I may or may not do that. :confused: lol. While it seems like it may be cumbersome to set up I suppose it will probably help me avoid issues in the future.
Thanks marcus!
