stamp / ident a curve into surface
I’m using curve mode in stroke setting with various brushes, and I’d like to simply apply the stroke uniformally to the surface along the curve. If i drag / brush along the curve, it edits the curve outline. Is there a way to engrave the surface along the curve lines ?
Do you have Zsub selected?
yeh, zsub is on, when I click it does press it in a little, so thats useful. I find if i drag its not a uniform amount. I found setting bend off and lock start end off is good too
