Square bracket keys stopped working at resizing brush
It was working this afternoon. I went out came back and now it’s not working. The square bracket keys no longer size the the brush. I’ve spent two hours looking for a solution but no luck.
The bracket keys are working fine in other apps and as far as I can tell all the other shortcut keys in ZBrush are working fine. I’ve tried initialising. The Plugins/Misc Utilities/Brush buttons work when I press them with the mouse.
Thanks for any help.
Accidentally solved the problem. Don’t know why it worked, must be a refresh type thing.
I loaded a brush and the problem went away and now all my brushes grow and shrink with the square bracket keys again. Whoopee!
im having the same problem and i cant fix it
nm. found out that i didnt even have that option under plugins. had to install a plugin to get it http://www.zbrushcentral.com/showthr…l=1#post941399
