Spotlight positioning question
Hey guys,
I ws wonderig if there was a way to snap spotlight image to teh model so that i dont lose teh positioning if i Zoom in and out? or at least a recall position a little bit like with Image plane plugin?
This is in order to sculpt a portrait using outlines as a guide
Thanks for your help
P.
The easiest way to store a view is to go into the Document tab and under zapplink properties choose one of the front/back/side views and it will store the current position of the model. You can then save these views and load them in later if you need those specific angles again.
as has been pointed by totyo use the the timeline so can easy go back and front or side according your needs…you store each position and move the timeline…
